Mech Addict
Supporting Member
- 1,299
- 695
- Jun 9, 2019
Jackson,
Wyoming
This is the Build Thread for Red & Rough. Reply below.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Good old left hand threads on old Mopar passenger (er driver’s) sides. - Theoretical engineers. Apparently I had it backwards (hah):I had a 80% success today with replacing Warn hubs. Each side had one broken bolt in the wheel housing. The pass. side came out pretty well. Used a left-hand 1/4” bit, and it ended up backing out while drilling. There was only like the last 1.5 threads of the old bolt in there. I used a brass fitting as a drill guide, to keep centered on the bolt.
After that the hub went right on.
The driver’s side was a different deal. I was making on progress with the drill, but then it stopped cutting. I tried a right-hand 1/4” and a 5/16, and a 1/8, but I couldn’t get much bite at all. I even went and bought new bits (left and right handed) but they wouldn’t cut. I believe I may have found where someone broke an extractor in there. I need to get some well-made cobalt bits and see if I can punch through whatever is laughing at my attempts.
I bolted the new hub on anyway. It’s been driving with only 5 bolts for at least 30 years.
