XC92
- 1,573
- 362
- Jul 22, 2020
Queens,
New_York
As part of my overall restoration project on my '92 Talon TSi AWD, I've been removing, cleaning, derusting, priming and painting various structural and mechanical parts, both to get rid of rust which over time can destroy these parts, and to make the car look nicer (anyone who spends any amount of time working under their cars would likely agree with this).
I'm talking about control arms, center and cross members, engine mounts, battery tray, brackets, etc. Some are more "important" than others, but they all serve a necessary purpose and benefit from being cleaned and derusted and just simply looking nice and as close to stock as possible.
To clean them I've been using various products like Purple Power, Super Clean (my favorite), Dawn, brake cleaner, alcohol, etc., and to derust I'm been using a combination of hammers, scrapers, files, manual wire brushes, brush wheels, abrasive wheels, grinding bits, rotary tool with grinding bits, sand paper and chemical methods.
Once they're as clean and rust-free as I could get them (there's always a tiny bit of rust that's hard to get out in crevices and such, and flash rust if I don't prime right away), I've then applied several coats of primer and then several coats of paint, all rattle can and almost all Rustoleum.
I'm happy with the paint I've been using, mostly either flat or semi-gloss black for parts, plus flat and semi-gloss white for under the car and the wheel wells (my Talon is white).
It's the primer that I still can't make up my mind about. I've used various types, from Self-Etching to Clean Metal to Rusty Metal to Rust Reformer.
All seem to get the job done, but I'm wondering which is preferably for this sort of painting of these sorts of parts, that are very clean and mostly rust-free, and which by the nature of the rust removal process are already mechanically etched and need no further prep.
Does it matter, or are they all basically going to be equivalent for my needs? Do some dry faster, take paint better, or result in a nicer finish? Are some better at covering up shallow rust pits or being sanded to remove drip lines? Any other considerations, say in terms of rust-proofing?
