Tribal_RS_96
- 92
- 0
- Aug 19, 2011
St. Louis,
Missouri
Hopefully Friday I will be able to finish up my newer 420a motor swap and start it, can anybody tell me what the oil pressure at idle is?
Note: This feature currently requires accessing the site using the built-in Safari browser.
4psi at 800rpm??
I said holy shit out loud..... 8psi????? No thank you! I would want double that.
5-8 psi?Mine is 80psi at cold start.Once warmed up, about 15-20 psi.warmed up,driving around 3000rpm she's about 50 psi.Gauge is hardlined into extra hole on filter adapter plate.Dummy light is still hooked up incase of emergency(wake my ass up)
For what its worth, when I had mine running with a Melling/Melling High Volume I always had around 80psi at a dead cold soak and once it warmed up it dropped down to 10-15psi...
Interesting.
Stock bottom end? Miles? Oil? What kind of psi at redline?
Ah, I see. Somehow I suspected that it wasn't a stock bottom end with miles .
My engine, before it was rebuilt (~109,000mi.), was about the same too.Even after 30k on it, pressure was the same.
My whole motor is stock(86.000miles),accept for the turbo kit.Every time I change the oil I use seafoam to clean out the motor real good.That stuff must work becuase my oil never gets brown.BTW I try to stay away from redline with the boost.I try to stay under 6000Ah, I see. Somehow I suspected that it wasn't a stock bottom end with miles .
