Szlaga
- 0
- Dec 21, 2003
Chicago,
Illinois
I recently bought a rebuilt 6 bolt block and head, both had zero miles on the rebuild. Basically just a stock rebuild with 1g rods and 2g pistons. The rebuild was done by a shop that has done hundreds of DSM and Evo engine builds and I have never heard of any issues with their work. I installed GSC S2 cams, Mitsubishi MLS headgasket, and L19s before installing the engine. I did the Motoman break in (http://www.mototuneusa.com/break_in_secrets.htm) as most people here recommended that. I have about 900 miles and decided to check compression. My readings were from (1-4) 120-120-140-150. When i add a little bit of oil to the cylinders I get around 20 more per cylinder. Just for peace of mind I retorqued the ARPs and then checked again with the same readings. I do not have a leak down tester so have not yet performed that. Im pretty sure the rings are to blame but am looking to see if maybe I missed something. Is there a chance the rings are still not fully seated? I have been using conventional 10w30 and have changed the oil after 20 minutes, at 20 miles, at 200 miles, at 500 miles, and now at 900 miles. Any opinions on why I am seeing such low and differing numbers?
