mini zilo
- 783
- 16
- Jul 17, 2006
Chicago,
Illinois
Alright I took out my rear differential yesterday. I separated the lower ball joint from the knuckle in order to pull the whole hub away to get the axles out of the diff. I separated the ball joint because I could NOT get the bolt out of the control arm. I got the nut off just fine, but the bolt with not budge. However, I accidentally tore the ball joint boot and all the grease leaked out. Now, since this control arm bolt will not come off, I would hope there is a way to replace the ball joint without removing the arm? is this possible? Thanks
