Oldsid
Supporting VIP
- 207
- 4
- Apr 26, 2006
Calgary,
AB, Canada
I just installed my new Excedy stage 2 clutch and the "thump" when I shift is much more noticeable. The drive shaft carrier bearings are already filled with silicone as per the VFAQ article. I have checked the lash on the differential by turning the drive shaft and measuring the play. I know that the limit of the rotational play is 5mm but I found that mine is 8mm. I am suspecting that the thump is due to excessive lash of the differential gear and would like to know how to adjust it. Does it uses shims? If so where can I find them?
I searched quite a lot but could not find any how to article on this subject.
