pianoman
- 708
- 2
- Dec 14, 2002
chicago burbs,
Illinois
I tried searching but didn't find anything. Has anybody ever put new studs in a 3bolt? Since that is normally where it shears off, I was thinking of just tapping it for bigger stronger studs? What do you think?
Pianoman.
Pianoman.
The axles do shear off right at the pumpkin. If you are really lucky, it will shear off inside, and just act like a plug. Then you can disconnect those 3 bolts from the hub, and drive home. Which is exactly what I did at the SO last year. Snapped my 3 bolt axle, disconnected it, then drove 350 miles home
