TyphoonZR
- 0
- Jul 16, 2003
Hey John, I just purchased a 91 talon AWD turbo automatic and I know nothing of the history of this car. I bought knowing that the tranny was puking oil. I pulled the tranny, found the front pump bushing had moved forward and eaten the front seal, it actually came out with the converter. So I bought a new bushing, and installed a new seal and filter, drove it for 30 minutes and it would appear the problem has returned, it is starting to leak oil already and at first it was fine.
At about 3500 rpm I have a bad vibration which I believe is the cause for the bushing going. I also have no O/D, when I click the O/D button, it seems as if it hits neutral. Does O/D use the brake band or do you suppose my O/D clutches are shot? Should I buy a master overhaul kit and replace the metals as well?
I do not want to mod this car, just fix it and sell it!
