Quick Timing Question...
so what do you think of of 15 degrees of timing towards the end of the pull? Should I go with increasing more timing towards the end of the pull, instead of having 15 degrees?
RoasT BeeF said:
Deffinetely more power to be made with only 15 deg. What is your knock count on that pull?
He won't be able to tell you that, it's a 2g running the pocketlogger software (I didn't see DSMLink in his profile).
Damn you 1g guys being able to see knock for so cheap!! :D
Can you post a 3rd gear pull from about 3k to redline. We will need to see the entire timing curve to make a good determination. Log just timing, rpm and o2 voltage and post up the log.
