Questions On 99 spyder gs
Trivium
Apr 4, 2010
Hampton, New_Hampshire
Hey guys just litterally bought a 1999 eclipe gs for 500 bucks. WHAT A STEAK. only problem is that it wont shift into reverse no worries thought because i can rebuild it. I'm still a n33b to mitsubishi's so i figured i'd ask u guys an engine question.
Should i swap it to the 4g63t
or just keep the 4g64
can anyone tell me the pros n cons of both n which one they would recommend doing n why
thanks
triv
what are your goals with the car? if you want to be turbo you can build it and it wil be a torquier verision of the 4g63
these are my long term goals
fwd to awd conversion
500+ hp
custom interior
i know there big goals but like i siad this project will take me about 2 years
Ok, well if this is a street driven car i would suggest building the 4g64 in your car now. To reach 500 hp your going to have to build internals either way. The turbo components will bolt up like they would to a 4g63 (after you swap to a dohc head from the 4g63). Decide what fuel you want to run (pump or e85) and pick your fuel system and turbo based off that.
As far as the awd swap there are write ups on that, just search. It is easier to do on the spyders i believe. You might as well find a cheap gsx parts car so you can pull various parts for your 4g64 build as well. You would probably save money in the long run.
I would also suggest swapping to an eprom ecu and running ecm link or getting a flashable ecu. Just search on here if your unsure what i'm talking about.
And throw up some pictures, you got that really cheap! O and make sure there is no rust, you definitely want to take care of all rust/maintenance FIRST.
good luck
like i was saying im still fairly new to the dsm's but ive been working on cadillacs my whole life. Since the 4g64 is non turbo. n im gonna need to spaw the 4g63 head. How would i end up turboing the motor thats my question. Sorry for all the n33b questions guys
BUmp BUmp Bump
