Talonman86096
- 206
- 4
- Feb 22, 2006
Elizabethtown,
Pennsylvania
Ok so heres is the question which may or not be a dumb question but I cant find an answer. Would a loose almost disonnected wire at the coilpack throw a CEL? I just recently changed my wires becuase I was having a stuttering problem at WOT and it fixed that problem. But yesterday I took a drive after letting the car warm up, and not far down the road the CEL came on and it started to seem like it was sluggish and booging down missing at lower rpm's but once I got it above 3000ish seemed not as bad, so I was thinking possibly a bad O2 sensor. I have link but I bought the car with it (2.5) and tried to pull a code but keep getting a command time out error and cant figure out what to do. So anyway today I went out and was just checking connections around the o2 and such and found that the one Plug wire was almost completely disconnected from the coil pack. I plugged it back in all the way and took it for a spin and it didnt seem to be exhibiting the same problem as the other day but the CEL remained on. I dont know if that could be all it was or if it still is something else that is only going to be intermittent. Any advice or ideas would be much appreciated. Oh and the previous owner told me that he has link set to ignore misfires I believe which made me think I wouldnt throw a cel for a misfire which I assume if the plug wires were loose it would be considered a misfire.
