Robert503
- 127
- 10
- Oct 19, 2008
Newberg,
Oregon
92 tsi awd
In the middle of installing the the prothane motor mount inserts and I’m trying to determine what insert is the one that needs to be pressed in. I will not be doing the rear roll stopper until I pull the trans to do the clutch. I’ve got the driver side and passenger mount already installed. I have some pics I will post at the end. The front roll stopper that came out did not have the non reusable nut that looks like it should have teeth on it to lock into the factory roll stopper(going off the service manual) and the bolt that goes through the mount was very loose fitting.
So what I have is a two piece mount and a mount that needs to be pressed in. The bolt fits nicely into the two piece mount and sleeve but the two piece mount doesn’t completely seat on the front roller mount. What made me question this is the two piece insert I have in the mount didn’t want to squeez back into the mount on the engine. Gut feeling is that I need to press the one piece Insert into the front roll stopper but then that leaves me with the bolt that doesn’t fit right into the sleeve, and the sleeves are not interchangeable between the two mounts. Also I just didn’t have the sleeve pressed in all the way in the pic.. Any help is appreciated
