Problems After Avcr Install
badas93tsi
495
Oct 17, 2002
Augusta, West Virginia
I just installed an avcr on my buddy's 95 gs-t, and now it bogs REALLY bad after you boost up. A better explanation; we went out to test it and it pulled fine up to the pre-set boost. He let off of it and immediately got back on it and nothing. The boost gauge was reading 0 because the throttle plate was open but the car acted like it he wasnt pushing the gas at all. After about 10-15 seconds it would catch and spool. I have no f'ing idea what the hell is going on. I wired it per vfaq pin layout, and oddrob told me how to do the vaccum lines. Anybody else have this problem, or have an idea whats wrong? The car ran perfect before the installation.
I forgot to mention that I installed an afc at the same time. The car still has the stock injectors because I dont have a logger to tune, so I was waiting on dyno time. Does the afc have to be adjusted for the stock injectors on a 2g? Its at 0% across the board on high throttle and low throttle. Anyone?
I would go back and recheck all my work first, look at the wiring and vacuum hoses that you tapped into most likely the problem is going to be in the work.
I figured it out, the directions I got off the internet showed the wrong wires intercepting the airflow signal wire. All good now, thanks for the help
