Problem with the Profec B
Mistaspakles
227
May 17, 2002
Ok, so I just installed my Profec B. The "IN" connected to the turbo, the "OUT" connected to my external wastegate, the "inlet pressure hose" that comes from the head unit was T'd off to where my boost gauge was T'd off (fuel pressure solenoid). So I take it out for a spin to get the settings. While on "low" I floor it in 2nd and my boost gauge takes off past 1.4 bar so I back off. I try it again and the same thing. What's going on here? After I floor it, when I let off the gas and the blow off valve does it's thing, I'm hearing somewhat of a rumling sound, like an enging rev sound. Anyone have any idea what this may be? The settings in the back of the head unit are set up for the "external wastegate" setting.
Also, is the head unit always on unless you turn it off? When I took my key out of the ignition, the unit was still lit. Is this right?
Did you tap the power to s source that constantly on.
it should turn off when the car is shut off.
unless your turbo timer is on.
Lue
Tap it from the lighter, its the easiest way. I tapped my pressure source from the BOV, not the boost gauge. May want to try that, mine works fine.
yea tap the bov....
  • Wanted 2g Looking for a clean title minimal rust roller
    Looking for a 97-99 eclipse GSX roller, has to be clean title with minimal rust. The closer to...
    • SBjunkiie
  • For sale Jmf race manifold
    6 bolt jmf race manifold throttle flange is for s90 Asking $400 plus shipping
    • spoolinjuice
  • For sale 1g 1G EDM Taillights for sale
    • Shaxzy
  • Wanted 2g Front glass wanted
    Hopefully some has one or has a lead on one but im having a hard tome finding any
    • 2gRhino
  • For sale Dynatek ARC-2
    Dynatek arc-2
    • FWD
