Hristo
- 2
- Jan 4, 2021
Texas,
Ohio
hello guys i have the following problem on my 1999 non turbo eclipse spyder.
Yesterday i drove about an hour in a raining condition i got home shut off the car everything normal. After that i go start the car and when i tried to shut it off it wouldn't, it kept running even after i pull the key. So i stalled it in gear and began searching.
I pulled the ignition key terminal nothing happened it stayed on then i go to the MPI relay pull it out and car turns off. I tested the relay it works fine. I used a multimeter on the relay terminal and it reads constant voltage to it.
any suggestions?
any suggestions?
