Please Support Kiggly Racing
Please Support ExtremePSI
Problem, electrical, Help please!! Also CEL P0440 help!!
chr0n03939
66
Sep 6, 2004
Lake tahoe, California
Ok, i have a 96 mistu gst. Fully stock. About 3 or 4 weeks ago i noticed a loss in power. My headlights were dimmed, My dash lights and radio light were also dim. When i tried rolling down the windows, braking or using the interior lights, they all made my headlights dim even more. It also seems to take a little longer to start up.
I checked the fuses, they are fine.
I went to a shop and they tested my battery and alternator. I don't know how well though. While my car was running he hooked up wires to my + and - terminals and on a handheld reader, showed me the numbers.
my battery was at 12.43 volts
my alternator was charging at like 14.73 volts.
What could be causing this?
my friends eclipse head its battery go out, but his car wouldnt start. He took it out had it checked at kragen, and they told him that it was reading good voltage but it wasnt outputting the enough volts. I'm getting mine checked tomorrow.
Could this be my problem?
Also my CEL came on the code P0440:evap control system malfunction. The guy said it was prolly something to do with my gas cap. I noticed that about a week after my CEL was on, i was getting gas and i used the little lever on the gas pump handle, so i didnt have to hold the handle myself. Well it overflowed. It didnt automatically shut off. Also sometimes i can smell gas at the rear of the car.
Could those problems be related?
Please help me i need it bad.
i doubt these 2 are related - the EVAP is your charcole canister.
Did you install anything electrical latly ?
no, i havent had anything done to the car. nothing installed, and nothing removed.
and are you positive about the charcoal canister?
I just got my battery tested at kragen, and they said it was a good battery it just needed to be charged. They charged it, and i took it home and instaleld it. I still have the same problem.
I've ruled out my alternator, becuase i had it tested and my car has been like this for almost 5 weeks now.
I've ruled out the battery because i've had it tested 2 times.
What coud be causing this problem? Someone help me.
also my uncle thinks it could b a bad ground, does anyone have pictures of where all the grounds are? I don't understand the chiltons wiring diagrams.
I can only find 2 grounds, both of which i found because of that site with then enigne bay pictures.
Vfaq didn't have any answers, and neither did google.
Can someone please help me?
I need any info anyone could give me, i talked to a former mitsubishi mechanic and he told me that he'd never seen this before... Am i screwed here or what?
Did you check the ground from the alternator? I had the same problem. The screw that held the ground cable to my alternator was loose and caused fuses to blow and lights to dim. Good luck!
:thumb:
