XC92
- 1,573
- 362
- Jul 22, 2020
Queens,
New_York
All 4 pads and rotors on my '92 Talon TSi AWD need to be replaced fairly soon, and I was going to go with Pro Stop kits. The cheapo service station generic ones now on the car are still serviceable, but the rotors need to be turned and stopping power isn't what it should be, so I figured it's not that expensive an upgrade since I'll replace them myself.
I was going to go with their "daily driver" kit, the Z23, which has the same pad material as the "performance" Z26, but with rubber shims to make them quieter, compared to the steel ones on the Z26, to better dissipate heat during extensive use under hard braking. But my Talon is stock, putting out no more than 200HP, with no near-term plans to upgrade this, and I don't race or drive too aggressively, so I'd probably be well-served by the Z23.
Thing is, I was on Amazon the other day, browsing through Talon-related parts, and saw that they had the rear Z26 kit for around $60, where it usually goes for around $150-$160. It was new and the current model. I didn't want to look a gift pad and rotor set in the mouth so I ordered it, and it arrives tomorrow. Assuming that it's new, in good condition and nothing seems off, I'll install it on the car.
However, I'm wondering if I now need to get a Z26 kit for the front too, even though I was all set to go with the Z23. Braking power should be the same with the Z23's, but the shims would be different, with perhaps a bit more noise from the rear, and VERY slightly more risk of brake failure from the front, which is where most of the braking is happening anyway, and thus more quiet too.
Should I match the fronts to the rears? Or would I be ok with Z23's in the front? Probably doesn't matter that much, I'm guessing. The difference is around $30. I'm actually more concerned about noise vs. brake fade than the price difference.
