eclpsegsx12
20+ Year Contributor
- 214
- 0
- Feb 16, 2003
Tucson,
Arizona
I need some reviews for the precision SC-61 turbo...you can buy it from dejon tool and its the 680 HP turbo....just wondering what your thoughts were on it...thanks!
Originally posted by gritsak
need more info on your setup and goals....the sc61 is really popular in the honda crowd, and the spoolup isnt as bad as you would think. i bet on a stock motor you would see full boost before 5k...might seem laggy to those nancy boys that want a 3k spoolup but if you want big power this turbo will make it.
Originally posted by TurboSpoolinIns
Exactly. A scm or sc61 will reach full boost before 5k, in fourth gear , you will see 20 psi at about 4-4.2k, which is not laggy at all imho. All this talk about lag; it's overrated. Just my .02
Originally posted by jdmawd
A 50 trim is efficient enough to run up to 26 psi on pump gas and knock very little. With good tuning and spool under 3800 rpms. Depending on what exhaust wheel and turbine housing you select. On pump gas a 56 trim turbo will get obliterated by a well setup and supported 50 trim car.
Maybe... but 22 psi on a 56/61mm power'd car can make over 400 easily on pump gas tuned right with little timing on 22 psi
with that boost hitting just over 4k rpm in 4th gear like I said. I'd take the 56 over the 50 anyday
people have different power goals in life.
Originally posted by MNGSX
I'm just going to run 98% ethanol E98 all the time ...
I can get it for around the cost of 93 octane..
I don't think you understand. While you are trying to get those huge wheels spinning up to 4500 where it begins to make boost. A 50 trim will be pegged at 25 psi a *thousand* RPM's sooner. you will be Bus lengths in the rear by the time you get that big bad 56 trim spooled to 22 psi.
Ones goal should be 600whp and 10's if they are selecting a 600whp turbo that is capable of 10 ET's
Good Luck.
Originally posted by entropy138
Thats why you downshift so you are in the right RPM range for your turbo.
If you're launching in first, stutterbox it at 6k and well, break the hell outta your driveline. You're 50 trim no longer has any advantage.
Yes, I agree, lag is overrated. There are ways around it.
Anyone daily driving around having a problem w/ lag because they are looking for boost below their turbo's spool up RPM's is a fool IMO. Downshit a gear and hit it, problem solved.
Just be aware of your turbos range before you order it and make sure you like driving around in the upper RPM's all the time if you are going w/ a big turbo.
Or just stroke your motor
Who said it isn't?
