Millinnion
- 74
- 19
- Mar 24, 2015
Puyallup,
Washington
So I have a 98 GST nothing added pretty much all stock. I just put a head that I had build on with all new OEM parts minus the cams. Have a set of comp work cams only 264s.
But anyways after installing I had an issue with the CAS connector and only spark on cylinders 1 and 4. I replaced the connector and a new CAS and got rid of the P0340 code but still only have spark on the 2 cylinders.
Decided after following all the troubleshooting on ALLdata got it down to what should have been the ignitor. So after all that story I bought a new ignitor put it in and now I have spark on 2 and 3 but not 1 and 4 . So I swapped to my old one just to see and sure enough spark went back to 1 and 4 and none on 2 and 3.
Did I most likely just get a bad ignitor? Any help would be much appreciated.
