Power steering fluid in the Brake fluid..opps
gtrej01
406
22
Dec 13, 2010
Granger, Washington
Ok, So i have a friend of mine that accidently put some power steering fluid in his brake fluid. :ohdamn: He stated to me that he only placed a little bit.
What would do you guys and gals suggest...Complete flush or do you think it will be ok as he only placed a little bit.....
Any help is appreciated, thanks in advance.
as long as he didnt use the brakes and mix the fluid around you can suck out all the fluid from the master and put fresh fluid in. otherwise you will contaminate the brake system such as any rubber components like inside the master cylinder may swell.
