sleeperhemi
- 82
- 1
- Sep 22, 2012
White Plains,
Maryland
Hi folks. So I finally have all of my lighting issues resolved and working great. After putting all the interior trim panels back in the car.....I turned the radio on for a bit and the antenna went up as it should. When I was done tinkering, turned the radio off and the mast stayed up......motor for the mast is functional and you can hear it moving but the mast stays up.
Anyways...im curious to know if any of you guys have completely removed the power setup and put a fixed antenna in its place? Does it work? Ive seen a few at local parts stores what are 2 or 3 inches tall but need a flat surface to mount so they wont work where the current power mast is located. What do you guys think? Any photos would be appreciated. Also, on the power unit, the plug that send signal to the radio so your stations will play........what is that supposed to plug into? If there is supposed to be a wire that comes from the radio all the way to the back of the car and you plug the antenna adapter into it.........mine is missing. That adapter hanging from the power antenna has nothing to be plugged into.
