21_Eclipse
- 103
- 1
- Jan 7, 2012
Van Nuys,
California
So im leaking water for sure i saw the leaks touched it and even tasted it. The water in my "reserve tank" if you will gets pretty much drained after a day or two give it three tops after refilling. It runs good when its cold but when it gets warm it starts yanking, studderin, struggling, but not having a too hard time staying alive.
So this is what i did... to try and fix it on my thoughts on whats wrong with the car im having the timing belt and water pump replaced hope im not making a mistake
can you guys help on what else could be the problem of this.
this is my daily
if it helps my dash shows 151xxx
