possible to change a CA ecu to federal/ std.
lil4x4dsm
Nov 7, 2002
hey guys, just a quick question. is ther a way you change a california ecu into a federal ecu. I pulled all my emissions stuff out of my car and you guessed it, my egr valve isnt working since i pulled its vacumm source.now my CEL is on all the time, i can clear it with my pocket-logger but once or twice a day gets old. i just clipped the "magical" pink wire to shut the abs light off on the dash while the logger is plugged in, but i want the CEL light off to. im tired of the "whats wrong with your car" questions when they see it. is there a capacitor or something i can clip to get rid of that???? any help appreciated.
greg
Simple... (ONLY 1Gs) Solder a 1K resistor into position 134 inside your existing ECU... 've seen this posted on the BADSM.ORG VFAQ... I just took it one step further, and soldered a pair of wires that go outside the ECU, so I can plug it in when I want, and remove it for smog testing (Thanx to a Molex plug, the ECU side has the two pins from the ECU's board #134, the other side of the molex has the 1K resistor). I used a 1/4 watt one for my ECU and it continues to work fine.
Hope this will keep the CEL bulb in your car... You'll never know when your ECU throws a different code!
Eben
94 TSi AWD
"Installers do it with Strippers"
thanks alot boosted, that was exactly what i was looking for. i will attempt to do that and let you know.
by the way, your led knock indicator and tt in that one tidy package is very wll done. love your car!!!!
thanks
greg
  • For sale 1g Oil return mhi
    1g oil returns
    • 92AWDHX40
  • For sale 2g awd rear hubs
    2g awd rear hubs with arp extended studs.
    • jweber
  • For sale 2ga Auto vss NOS
    2ga auto vss sensor and and driven gear. New old stock
    • jweber
  • For sale 4G63 Dynatek Arc-2 brackets
    Dynatek Arc-2 brackets. Were originally for mounting the box on an Evo. Stainless. One has...
  • For sale Evo3 16G
    Bought this from a member here. Used it for about 150 miles then swapped it out for a more...
    • silentsnow31802
