DSMJim
- 3,328
- 41
- Jul 24, 2002
I saw threads about others porting manifolds etc etc and thought I would do my own. Here are the results. The first pics of the before and after in the collector and I matched up the exhaust housing on my 50trim to the manifold as well. Some of the runners were off quite a bit and needed to be opened up. I removed quite a bit of material in the collector and re-shaped the ports so they direct straighter into the exhaust housing of the turbo. Should work out pretty well.
Before
After
Runners
Exhaust housing
It was easy enough to do, however took around 4 hours. I started with my air grinder using grinding stones to open up and shape the ports and collector how I wanted. Once I had it shaped how I felt was best I used my dremel with a sanding tool to smooth it all out.
Before
After
Runners
Exhaust housing
