zachsEVO3
- 169
- 2
- Apr 1, 2008
Ithaca,
New_York
My clutch pressure died while driving one day. Had it flushed, then it lost pressure again within a few miles after. Look what I found floating in the fluid... I'm guessing this isn't normal.
Actually, I had problems with it randomly loosing pressure in the winter at random times after that, then it would return to normal after a few minutes and then its been okay from January until now. First I assumed the slave cylinder which was replaced with the clutch in November or some leaky bit/ air in the line .
So is it safe to assume that this is my problem and I should probably replace the Master cylinder? Rock auto pats okay?
