1. Join the Community!
1G Piston to wall clearance !
Posted by SasaniFab, Jul 11, 2020
Please Support ExtremePSI
Please Support Feal Suspension
  1. SasaniFab
    SasaniFab Freelancer
    2,383
    688
    Joined Dec 1, 2013
    danbury, Connecticut
    THis topic has been discussed a bunch of times. My friends came over recently and we discussed the specs they planned on running for their new build. The ptw clearance ended up being over .008 with ring gaps in the 30s . I don’t think this is a good idea even when using forged internals. Have any of you heard anyone running this wide of a clearance and been successful?
    Street Build 4K  20
    1992 Eagle Talon TSi
    645 whp · 498 lb/ft · 1G DSM
    Loading...
  2. bastarddsm
    bastarddsm Proven Member
    5,261
    1,081
    Joined Aug 26, 2003
    Mendota, Illinois
    That's pretty sloppy. My old shortblock is up near 0.007" now, and it seems to not have very good oil control. Still made good power though.
    Showcar Build 6K  1
    1991 Eagle Talon N/T
    9.805 @ 144.00 · 1G DSM
    Loading...
  3. donniekak
    donniekak DSM Wiseman
    5,608
    938
    Joined Mar 23, 2008
    Surprise, Arizona
    It depends on the piston. Not just material, but design.
    A slipper skirt piston will flop around a lot more than a full round. The amount of “barrel” to the shape matters a lot to.
    Street Build 4K  0
    1991 Eagle Talon TSi AWD
    manual · 1G DSM
    Loading...
  4. SasaniFab
    2,383
    688
    Joined Dec 1, 2013
    They are standard arias pistons , that seems like a lot of clearance , at that spec I can’t imagine you need to file the rings
    Street Build 4K  20
    Loading...
  5. motomattx
    motomattx Proven Member
    2,948
    1,013
    Joined Dec 9, 2010
    wampum, Pennsylvania
    You could expect collapsed skirts or cracked skirts and oval cylinder walls with that type of clearance, thats way too much.
    Drag Race Build 4K  24
    1995 Mitsubishi Eclipse GST
    fwd · manual · 2G DSM
    Loading...
  6. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    6,468
    2,758
    Joined Nov 14, 2013
    Independence, Kansas
    Just for reference, I built a Small Block Chevy Corvette 327 back in the 80's. Didn't have the $ to bore and get new pistons back then. One cylinder had .011 PTW clearance and others were well beyond normal but that was the largest PTW. It had factory cast 11:1s and the skirts had been knurled to bring them back out a bit for less slop, needless to say it should have been bored and new slugs.
    I ran that motor to 8k in my 1973 V8 Vega, threw a 150 NOS shot on it and it never gave me any problems. Ran great and really never even used oil.
    I agree with others that .008 is to much PTW but wanted to tell the story so you know that they will run but it is a crapshoot on if it will hurt pistons under pressure. Since a SBC piston has more of a skirt then a DSM piston, it held up and didn't rattle around like a DSM piston will.
    Here was the car it was in, circa 1985.
    Pops
    Street Build 5K  29
    1992 Eagle Talon TSi AWD
    14.74 @ 117.04 · 1G DSM
    1K  14
    1990 Mitsubishi Eclipse GSX
    awd · manual · 1G DSM
    792  18
    1967 Chevrolet Camaro RS
    rwd · automatic · Misc Vehicles
    Street Build 1K  7
    1998 Eagle Talon TSi
    Street Build 6K  14  25
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 · 1G DSM
    Loading...
    buddahboost likes this.
  7. motomattx
    2,948
    1,013
    Joined Dec 9, 2010
    Oh the Vega and the Pinto, what were the companies thinking back then? they did end up being good for engine swaps though I guess, you see them with big hp engines at every track, they should have just made them with V-8's when they were new, then there was what the Vega Cosworth or something? some high performance version?
    Loading...
  8. SasaniFab
    2,383
    688
    Joined Dec 1, 2013
    And I thought .005 was a lot of clearance, I’m looking forward to seeing what happens when they start the engine. The real problem around here is that if you are looking for machine work done your going to wait 2-3 months. They didn’t wanna wait that long so instead of over-boring they honed with a torque plate.
    Street Build 4K  20
    Loading...
    1990TSIAWDTALON likes this.
  9. motomattx
    2,948
    1,013
    Joined Dec 9, 2010
    2-3 months is the norm for about any machine shop in the summer, maybe even in the winter around here, that kind of stuff needs to be planned and the block dropped off asap when your planning a build of any type, people are too impatient these days.
    Loading...
  10. SasaniFab
    2,383
    688
    Joined Dec 1, 2013
    My machinist usually can have stuff back to me in 2/3 weeks
    Street Build 4K  20
    Loading...
  11. 1990TSIAWDTALON
    6,468
    2,758
    Joined Nov 14, 2013
    We have alot of dirt tracks around here and my machinist is a good month or more on wait time also. Alot of LS stuff in that place and a big old Buick straight 8.....
    Street Build 5K  29
    1K  14
    792  18
    Street Build 1K  7
    Loading...
  12. Buddy2
    Buddy2 Proven Member
    104
    24
    Joined Oct 7, 2013
    Helsinki, Europe
    I think going by piston manifactor recommendations on clearances is best way to go as there is alot more than diameter of a piston at play. Ring gaps has more room to play depending on boost and compression.
    346  9
    1992 Mitsubishi Eclipse GSX
    152  0
    manual · 1G DSM
    631  8
    Loading...
  13. jed344
    jed344 Supporting VIP
    862
    111
    Joined Jan 10, 2008
    Waterville, Iowa
    That is a very large PTW. i target .0045 normally with a build that will be seeing some serious duty. I have heard of people running .005ish, but never that large.
    1K  38
    1997 Mitsubishi Eclipse GSX
    awd · manual · 2G DSM
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
