gutoblauth
- 2
- Jan 23, 2020
Novo Hamburgo/RS - Brazil,
South_America
Not long ago I heard some noises coming from the engine bay that seems to be electric/coils noises, but the mechanic thats doing my car said it was from the PCV valve. I also found some people here saying the PCV valve actually does this kind of noise. (Not sure about its worn)
Couple of days ago I headed to to the mechanic again to do some clutch drain and I told him about some power issue at low load. He noticed the engine running rich, so he looked for a possible eletrical issues. He removed a spark plug wire from cyl 4 while engine was running and some sparks/arches could be seen leaking trought the cable conector on the coil side. He said that was not supposed to happen and that I may need to replace the coils from cyl 1/4.
So now I don't know if its eletrical or the PCV valve. I was looking into replacing the PCV valve since its cheap, but I can't find it anywhere I live and I was wondering if it can be replaced by other engine PCV valve available here so I dont have to wait and pay import taxes from a cheap thing.
