Sjd6795
- 614
- 121
- May 14, 2014
Wilsonville,
Oregon
Thought I would share my current parts I have in the process of building my engine. I don't have the main things like rods and pistons yet because I am waiting to get my block machined when I have the time. I expect sometime a month from now is when I will start the engine build.
Pictures below
All parts will be brand new other then obvious parts that are no longer being produced.
Current build cost for everything under the engine bay and any electronics will be around $5,500
Current parts:
Total estimate: $2,308
6 bolt black lower timing cover
1g 4 ply double walled silicone radiator hose kit
3" air filter(no brand)
aem wideband o2
gates water pump
Oem timing belt kit with gates blue kevlar belt and BSE kit
Oem head gasket
cometic engine gasket kit
throttle body gasket
punishment racing boost controller
boost gauge(no brand)
3" gm mas with translator
850cc low impedance injectors from rci
190lph walbro fuel pump
1g megan racing downpipe
2.5" sidemount intercooler piping
clear upper timing cover
cast aluminium dual gauge pod
STM fuel pump rewire kit
Rebuilt and powder-coated 18g turbo by me
STM egr block off plate
Parts to order:
Total estimate: $2,749
Manley 8:5.1 pistons
eagle H-beam rods
ECMlink v3
268/272 BC cams
manley intake and exhaust valves
manley valve locks
manley springs and retainers
GSC zero tick lifters
GSC valve stem seals
supertech valve guides
Pictures below
Current parts:
aem wideband o2
gates water pump
Oem head gasket
Parts to order:
eagle H-beam rods
ECMlink v3
268/272 BC cams
manley valve locks
