SwiftKidGSX
- 100
- 7
- Jul 11, 2003
Cerritos,
California
The following parts are for sale and ready for pick up in So.Cal. Most parts are for a 2G.
Please PM or text (562-608-7696) for any questions
Will shoot pictures on request.
Shipping is available.
Thank you,
AC Condenser $60
AC Compressor $175
AC Lines $65
Alternator $75
Battery Tray 2G $20
Crossmember FWD Turbo 2G $30
CAM Gears $20
CAS with pig tail $50
Clutch and Pressure Plate NEW [No Name] $100
Coil Pack 1G $30
Cylinder Head $150 2G [Head Only] $200 1G [Head Only]
ECU Blackbox 98 FWD SOLD
Exhaust Downpipe FWD $40
Exhaust Manifold $40
Exhaust Manifold Shield Set 2G SOLD
Flywheel 6 Bolt OEM [NEW] SOLD
Front Axels 2G [Pair] $50
Fuel Injectors 450cc SOLD
Fuel Pump Hanger FWD 2G $75
Fuel Rail 2G $45
Harmonic Balancer 6 Bolt [NEW] $20
Headlights Set 2G $60
Ignition Translator SOLD
Injector Translator $25
Intake Manifold 1G $40 2G $40
MAF 2G $30
Manuel Engine Harness 97-99 SOLD
O2 Housing $30
Oil Housing Air Cooled SOLD
Oil Pan 1G $60
Passenger Airbag 2G Grey [Peeled back] $20
Pillared Trim Pieces Grey 2G $60
Power Antenna 2G SOLD
Power Steering Pump 2G $30
Throttle Body $50 2G SOLD 1G
Throttle Boby Elbow 2G SOLD
Timing Belt Cover SOLD
Radiator W/Fans 2G $40
Radio Bezel 2G $25
Radio Brackets 2G $25
Rear Lights [3 Piece] $85
Rear Wiper Motor $35
Rear Window Trim Pieces $30
SMIC 2G SOLD
Spark Plug Cover SOLD
Starter 2G $25
Transmission FWD 2G $300
Valve Cover SOLD
Water Pipe $40
Water Pump [NEW] $10
Performance Parts
ACT 2600 Clutch and Pressure Plate [Used] $100
ARP Head Studs [Used] $50
Greddy EBAY BOV $50
Injen Intake [New Filter & MAF adapter] SOLD
MBC $25
Megan Racing FWD Catback $200
Lower ICP J-Pipe to SMIC SOLD
Upper ICP from SMIC to TB SOLD
Spark Plug Wires NGK [NEW] SOLD
Spark Plug Wires Magnecor $30
Thank you,
AC Condenser $60
AC Compressor $175
AC Lines $65
Alternator $75
Battery Tray 2G $20
CAM Gears $20
Coil Pack 1G $30
Fuel Rail 2G $45
MAF 2G $30
O2 Housing $30
Oil Pan 1G $60
Radio Bezel 2G $25
SMIC 2G SOLD
Starter 2G $25
Valve Cover SOLD
Water Pipe $40
Performance Parts
Greddy EBAY BOV $50
MBC $25
