Cfrakes
- 61
- 2
- Jun 6, 2021
Idaho
So I got 2 codes one says the engine is running too rich and also the P0442. Could those both be from one cause? Also could a EGR delete cause the P0442?
I noticed very once in a while the gas pedal doesn't respond and also sometimes the car will crank right over and start up but then die instantly then stay on after the second startup.
Any ideas as to what to look into is appreciated. I have replaced the gas cap and fuel injectors already. Thanks
