Kryndon
- 944
- 591
- Jan 10, 2014
Bulgaria,
Europe
Hey all,
Put short, I'm looking for pistons with these exact specifications:
85mm diameter, compression height 1.130", stroke 100mm, rod length 150mm, compression ratio 10.0 : 1
I will be using them in an N/A stroker build, from 2L to 2.3, hence the increased stroke. I'll be using a crank off a 4G64.
The only pistons I could find with these specs are manley pistons: https://www.extremepsi.com/store/product.php?productid=25777&cat=1662&page=1
My questions is, do you know if any other type of car comes stock with these pistons? Or maybe a different brand which does the same specs?
