FORMONTOYA
DSM Wiseman
- 2,259
- 57
- Oct 7, 2004
Houston,
Texas
doing a turbo swap...got the exhaust mani off this weekend and found a lot of oil in the exhaust ports of #1, 2, & 3 (#4 look good for a head w/95k on it). bad seals and/or guides...time for a rebuild. my question:
1) is there anything special or different that i need to be looking for on the head or bottom end when i get the head off? ...crank freeplay, ect...
2) would it help to do a compression test before the head come off? or will the leaking seals in the head affect this and give an unreliable reading?
3) should i just go ahead and yank the motor and freshen up the bottom end (car really ran great up until the turbo took a dive)? only plan for 300 whp so it should not break the bank...but it will put delays into the project. be nice to get away from having to do the whole motor.
of course i am about 10k away from thinking about a t-belt change...so that and the other related items are going in with the fresh head. any suggestions will be helpful.
thanks,
jim
this is what happened this weekend...
http://www.dsmtuners.com/forums/showthread.php?t=164239
thanks,
jim
