dsm_dan
- 31
- 0
- Oct 20, 2002
ok here goes.
1st of all i checked all over and checked vfaq and got a "can not find server"
mods and such
1990 6 bolt block
2g pistons
new timing belt water pump and tensioner
ported head
all new bearings
Thats about all for the longblock
(balance shaft belt was left off since when i took the timing belt off the balance shaft belt had already been torn up in 3 pieces... again, this is not "removed" just no balance shaft belt.
not sure but the oil pump timing mark MAY have been off a tooth
ok anywas:
The oil pump has a shaft that goes through the block on the back side. Just like the balance shaft only the balance shaft is in the front. in the middle of this shaft there is a circular cut out in thw web casting of the block and a rod bearing type bearing secures the shaft in the webbing" of the block... a "sleeve" if you will.
Now, after i put the belt and all that on... the car started making a metalic buzzing noise... sort of like if you hold a screwdriver on fan blades or if you ride over a can with a bycle and it gets wedged between the forks of the bike. (
best way i can describe it) I figured the belt or a pully might be rubbing on the timing cover... so i take the timing cover off and run the car... still did it but by this time it got considerably louder AND the oil pressure was piss poor... not so little that the rod bearings and such were being neglected but considerably low... would not go past the 1st "notch". Anyway, i pin pointed the noise... coming from the pan.... very loud. So i drop the pan and there is the sleeve for the oil pump shaft all chewed up by the crank and other rotating assembly peices. so i look up nad give the oil pump shaft a good look and i notice that the shaft is flapping all round with a GREAT deal of play. (definately the noise ). then i see wher ethe sleev goes and i notice that from spinning fast and out of whack, the shaft is worn and chewed up... as is the block. In other words, there is no way even with a new "sleeve" that the shaft will not have tremendos play in it. The oil pump sprocket is tight and fine... its the whole shaft in the block that is wobbling. Later on i notice the balance shaft is basically the same deal. and there are balance shaft eliminator kits. now, i just didnt put teh belt on the balancer shaft... just left it be without a belt.
could this have cause the wearing of teh sleeve and surrounding block area? or maybe the oil pump sprocket was off a tooth or 2?
also, can you eliminate the oil pump shaft (aka second balance shaft i heard it's called also) this way i dont have to worry about the chewed up area in teh block where the shaft went?
ill try to get pictures, what do you guys suggest i do?
How should i tackle this? Has anypne here ever expeirieced this "oil shaft wearing out" deal before??? im lost and dont know where to start and who to ask. And its kinda vague and not easy to see what im talkin about but its the best i can do, thanks guys!
it would be great if i didnt need a new block and i could just take the whole shaft out and not worry about the damned thing, this whole rebuild has killed me !!
mods and such
1990 6 bolt block
2g pistons
ported head
all new bearings
ok anywas:
