Resolved Oil pump set screw
NOSLO2PT0
20+ Year Contributor
2,686
244
Aug 31, 2002
Joliet, Illinois
This my first 7 bolt car. Plus it’s been MANY years since I’ve had a front case/oil pump out. Is this an OEM front case/oil pump with this set screw holding the oil pump on? I don’t remember this screw on my 6 bolt. Is there a way to get a replacement screw, as I had to cut grooves in mine to try to remove it.
Sorry I didn't see your thread.....I have a handful from case tests. My bad.
I use and impact driver until it just breaks it loose btw. Prop up the back side with a pc of wood for cushion.
