99BoostedRS
- 390
- 0
- Apr 21, 2009
Queens,
New York
So recently i changed the oil in a eclipse because the light was on(Long story short the car was supposedly low on oil for about a mile or 2) and my friend wanted to install gauges in it. So we change the oil install the gauges and turn the car but only to see the oil press. gauge and the oil temp. gauge not moving
(after a while the pressure gauge will jump up and down) but the volts gauge was perfect. Also the oil light is on and it flickers
. We did everything by the book filled the oil filter with oil, shaked it a little to get the bubbles out, put oil around the gaskets of the filter and adapter. There are no leaks AT ALL not even a drip from anywhere.
Bad oil pump maybe?
Bad oil pump maybe?
