msisto
- 37
- 2
- Jun 30, 2018
Rochester,
New_York
Was trying to reconnect my oil pressure switch because the wires came loose at some point and were torn off on the road. I spliced the switch wire to the green wire (yellow?) below (not the one next to the word "ground"). I realize now that this isn't the right spot and I have the proper connector for the oil pressure switch.
My question is, where does that yellow/green wire actually go (the one with the zip tie on it)? it was cut, so I have no idea where it is supposed to be. Does it just get spliced with the switch wire to connect to the warning light? I read somewhere that they were supposed to be connected, but I'm not sure and can't find an exact answer.
