Ouroboros
- 0
- Jun 18, 2015
mesquite,
Nevada
My Oil pressure gauge isnt working. When i turn the key all the way w/o starting, the needle moves to about halfway on the gauge. But when i start the car the needle drops down and doesnt read. I read through the oil pressure threads on here and cant figure out whether the issue is the gauge, sender, or wiring. Also, the wires to the sender and oil pressure switch read about 12v so it cant be a wiring issue right?(hopefully) One of the other threads mentioned briefly that when the key is turned all the way, the oil light should turn on in the cluster but mine doesnt. Could it just be the bulb/fuse? If so, whats the fuse labeled as? Ill update as i keep working on it. For now im gonna go get some new female fittings for the 2 wires, theyre kinda loose. pic - keys turned all the way
