Please Support ExtremePSI
Please Support STM Tuned
420A 2gNT Oil Leak
Slow_Rs
50
Oct 23, 2020
glasgow, Kentucky
I’ve checked a lot of places for the leak and can’t seem to pin point it, i’ve changed the oil pan gasket, the filter doesn’t leak, and i’ve also changed the valve cover gasket, the oil will drip off of the crossmember from behind the block, compression is good and no liquid or anything on the plugs.
Any help is appreciated
Oil leak? Welcome to the 420a world.
Based on the info you gave, it sounds like it could be leaking from the oil pressure sensor (OPS).
alright i’ll check that out, something i’ve noticed too is that it only leaks while the car is running as well, cod that open more options?
