allezgrand
- 85
- 0
- Dec 11, 2003
Boulder,
Colorado
I've got a pretty bad oil leak on the timing belt side of the engine. I apparently had two, because I fixed one that was leaking where the oil filter unit mounts to the block, but it is still dripping quite a lot from that side of the engine. I took it to the car wash, removed the upper timing belt cover and hosed it down very well. I waited for it to dry while I let it idle, and after idling for about 25 minutes, it showed no signs of leaking anywhere. On the 15 minute drive home, I checked it several times (without pulling off the upper timing belt cover) and it was dripping more and more. The first place that it was wet at all was on top of the water pump housing....which led me to my next question: Is there any oil that is supplied to the water pump on these cars for some odd reason?
I recently replaced the head and used a metal head gasket, but I was a dumbass for not replacing the cam seals on the used head that I bought, so I know that that is a possibility and last time that I was under the timing belt cover the front main seal was dry. My main question is stated above, but are there any other possible places that oil could come from on that side of the engine?
