DarthBulk
- 644
- 9
- Jun 11, 2003
Waukesha,
Wisconsin
I am looking for some tips from anyone who has been in a similar situation to this. I just spent the last 5 months resurrecting a 1992 Plymouth Laser RS Turbo AWD that had been sitting for 6 years with a blown engine. I had the head professionally rebuilt, and the engine shortblocked with Mahle pistons by a reputable shop. I then assembled the engine, after sandblasting and powder coating every single bracket and piece that I had taken off the car. It was a lot of work. I also rebuilt the entire brake system, and the front control arms and even the cross members under the car. After all the work, I started the car and it ran beautifully. I sold the car to my dad, who then drove it carefully for a little over 500 miles to break the engine in. I had installed a manual boost controller, and tried to turn it down as far as I could, and it was easy to drive the car without going anywhere near 15 psi. We didn't dare drive it hard during the break in, but as a consequence of that, I didn't know exactly what the maximum boost level was set to. That should not have been a problem, because we knew enough to not drive it hard until the engine would be broken in. I was going to go to my dad's house last weekend to set the boost level for him. He said the car was idling high (from 1200 to 2000 rpm, depending on temperature) so he said he would take the car to a shop and have them set the idle down before I came on the weekend to set the boost level for him. He dropped the car off in the morning at the shop, and they thought they would get to it by the end of the day. Well, my dad arrived at the shop after work, and walked into the following scene. The shop owner was standing by the Laser, drumming his fingers on the roof, talking to one of the mechanics there. There was smoke coming out from under the hood of the car. My dad was appalled, and asked what was going on. The shop owner tried some fast talking, and said he had taken the car out for a "test run" before they even started to check the idle. When pressed further, he said he "only took the car up to 3000 rpms and then the computer shut it down". He claimed there was no damage, it was only power steering fluid that was sprayed all over the engine. Well, my dad took the car away from them and drove it home (only about 1.5 miles). I looked at it this weekend, and found that it was NOT power steering fluid. There was OIL everywhere. It seems to be coming from somewhere down by the exhaust manifold, and the whole front of the engine is dripping oil onto the ground. There was even a lot of oil pooled under the spark plug cover, but none down in the spark plug wells. My guess is that the head gasket is blown, and oil is being forced out where the head meets the block, but I don't know for sure. I think what happened is that the shop owner took the car for a drag run, and since I don't know what the maximum boost was set to, he probably horribly over boosted the engine, hit fuel cut, and blew the head gasket. He WAS TOLD it was a brand new engine with only 500 miles on it, and he had NO PERMISSION to drive the car...he was only supposed to set the idle speed.
So my questions are these. Does this sound like a blown head gasket, or could the oil be coming from something else? I didn't see any coolant in the oil, and the car still runs, but it is pushing a lot of oil out somewhere by the head. The brand new turbo (MHI EVO III 16G) doesn't seem to have any oil leaks.
My other question is about legal recourse against the shop. I talked with a lawyer, and he basically said there isn't much you can do. You can take them to small claims court, and that is about it. Has anyone else been through a situation like this? Do you have any tips about how to get the shop to pay for repairs?
Needless to say, I feel awful about this whole deal. I have a lot of time and money into this car, and it makes me sick to think a lame-brained fool of a shop owner took it for a joy ride drag run just for his own jollies, and ends up doing this kind of damage, and then claiming he didn't do it.
