1. Join the Community!
Oil from head
Posted by tylercuevas93, Jun 20, 2013
Please Support ExtremePSI
Please Support STM Tuned
  1. tylercuevas93
    tylercuevas93 Probationary Member
    5
    Joined Oct 19, 2012
    Valparaiso, Indiana
    Hello all. just around the beggining of the year I picked up a 97 gst spyder. I've read up on oil leaking from the exhaust manifold and i will be buying a new exhaust gasket with new exhaust studs from arp (broken stud) and I read that I need to put some kind of stuff on the back sides of the studs and it will prevent the leaking. But another concern I had was oil on top of my head in the dish where the spark plug wires are. Maybe assuming i need a new valve cover gasket? Not to sure. Any input would be much appreciated. New to the forums and never really been the best at forums so excuse my wrong posting place or anything else.
  2. mchustle
    mchustle Proven Member
    801
    Joined Aug 8, 2009
    johnson city, Tennessee
    There is one stud on the mani that goes to an oil galley, if I remember correctly it is the bottom middle stud.
    As for the oil on vc could be a leaking vc gasket or your oil cap, both of which are cheap and easy.
  3. Gomes
    Gomes Proven Member
    67
    Joined Jun 3, 2012
    Brantford, ON, Canada
    It would most likely be your oil cap as mchustle stated. Very unlikely the valve cover gasket. Had the same problem before.
Share This Page
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
