PIMking
- 2,781
- 4
- Jan 29, 2008
tuscaloosa,
Alabama
yes I searched but no one really answered the question that I had,
My stock 91 housing is crushed so I am losing oil into my coolant. my question is on the stock 91 housing can I just loop the coolant lines that go into the housing and there are two big plugs on the back side. Can I just find a fitting that would go into those said plugs and run an external oil coolant radiator deal?
I know the stock housing isn't cheap by any means and I was dumb and didn't take it off my 90 before going to the junk yard.
any help would be great!
I don't know the effects of just running without the cooler hooked up at all on a turbo car but I'm sure it's better than coolant in the oil...
(but add 30 dollars in fittings and lines if you want to get technical)
