EC17PSE
Freelancer
- 5,691
- 3,047
- Nov 1, 2008
London, UK,
Europe
Custom made oil catch cans. Fully enclosed system which is ideal for maximum vapor extraction.
I had some spare material left after making mine and a few people was interested so i made what i could with whats left.
This is not my normal offering so not many going to be made.
Dual baffled insides and also dual filtered,
Internals are designed in a way so that it houses the collected oil and stores it in the lower part.
Dual filtration means you will get alot more vapor/oil/condensation collected and much cleaner air going back through the system!
Holds safely 500ml / 1/2" liter but can just about get 600ml in to bring it just over the top of the sight glass.
Comes with 2x 10AN IN ports and 1x 10AN out ports.
1x 6AN oil drain on the bottom can be capped or a fitting and hose for a longer oil drain location (longer means you can add more volume of oil inside)
The bracket has 2x 6.5mm holes.
Size of the catch can itselfs is (not including bracket height and depth)
6" wide/width
5" long/height
3" deep/depth
The unit is scotch brite finished.
Price is posted and insured within lower 48
$350
Any questions please ask
6" wide/width
5" long/height
3" deep/depth
$350
