KeelesKustome
- 882
- 15
- Dec 29, 2007
Waverly,
Tennessee
due to posting this in the newbie area, and being colded i have moved it here.
decided to shave the fogligt also enlarged the intercooler mouth opening. holes with lord fusor, the same thing we repair ripped bumpers with.
i was going to shave the emblem, but aftermarket bumpers come without it and i didn't want it to look like a non oem bumper, so i decided to keep it.
a lil more progress I chaned the opening by cuting it 2" higher than it was for more of a mouth opening. I've started wetsanding it here.
I should have taken more pictures along the way , brain fart on my part.
Things i used:
1.142 lord fusor extreme bumper repair
2. mesh tape acutally i used drywall tape, it's the same stuff.(first page discribes the usage)
3. 80 grit sand paper on a orbital DA to cut down the new material.
4. poly flex bumper repair, it's similar to metal glaze but it's designed to be flexible for bumpers,(this was used to further asure the contore in the shave hole was correct.
made by Evercoat, poly flex, flexible polyester glazing putty. part #100411
5. die grinder cut off wheel to cut the opening for th IC bigger.
6. fine line tape to measure out and put the curve back where you want it at the top of the bumper. lay the tape on the bumper with the new curves , make sure it's porportional and then cut it precisely on your tape line with the cut off wheel.
7. an angle grinder with 50 grit disk, this is used to put the oem curve back in the bumper as the cut off wheel cannot, you'll grind it down slowly contoring the new part to the tape line you had laid.
8. 180 grit on a orbital DA, use this to finish out your poly glaze and use it to make sure your new cut out is smooth and free of any jaged edges,, fix any other bad spots on the bumoper and prime,,,reprime after wetsanding if nesicarry, then paint. i used the 3 step (the correct way) single stage on the bumper, as it's a front bumper and will have minor damage done to it as a dd.
some paint faqs i've posted are here at this link.
http://www.dsmtuners.com/forums/appearance-interior-exterior/72599-dying-failing-clear-coat-merged-7-8-cote-clearcoat-paint-dead-flaking-peeling-rot-5.html#post152061951
on page 5 of that thread.
I am a automotive paint technician for my job, and have been for 8 years,
i did not buy the bumper,,, it's the oem on my car,
I did not cut out anything to fill the foglight hole, i used normal masking tape to tape the front of th bumper to the conture i wanted it,
I then laid my drywall tape in that from the backside, 2 layers,
i then used the LordFusor 142 Extreme Bumper repair and spread it in pushing it through the mesh tape, while at the same time using 7-8 more layers of tape into it similar to laying fiberglass, your just using i different product,
this stuff will go off fairly quickly in 80 degrees or hotter. you then flip the bumper to the front side and remove your masking tape, and sand it down so it can have something to adhere to, if need be to make the round contour even more pronounced, you may use a lil more of 142 on it, if you taped it off correctly a lil bit of poly-flex is all you should need.
you do not cut and splice other bumper pieces into the process because the more edges you have, the more week spots you will actually creat and it will more than likely crack out. this is why you remove the entire foglight assemble and fill the larger hole.
I actually used spies hecker paint made by dupount, it's just their european line.
ohh yeah i haven't used he polyflex with just the tape, i am sure it would make a pretty strong bond, but it has never been taught in any of my I-Car classes, so that tells me it's probly not recomended, although , that does not mean it will not work, if you do it let us know the results.
few up to date photos with the front bumper just sitting up their.
Things i used:
