OEM Heat shield refinishing
Justin DuBois
1,757
1,511
Aug 15, 2019
Oakland, California
Steel-It stainless steel spray paint
Back when EGT probes were a thing, and the tuning method with AFC was to find the lean setting before the EGT temps jump ( which is actually the lean setting before knock and timing is being pulled back ) I was wire bush stripping corrosion and rust from stock heat shields.
To stop the rust, I would prime the stripped metal with cold galvanizing spray, and then top coat with Stainless Steel spray paint.
I had no idea how well this would hold up - but now I do. Check out the old heat shields at the top if the image. These lasted. 10’s of years.
The middle shield is recently stripped primed and painted, and the lower shield is brand new factory part for comparison.
You can all thank Mike W at RRE for letting me experiment 20 years ago, and the luck to find a product that still exists today.
Looks good that, nice and subtle. I recently did a friends 1GA talon but in a ceramic grey but his was cracked and a bite worse off to start with, age got to it but its not used a whole lot either. Its nice they got a sprsy thats so subtle to look at and almost looks like a factory finish
Definitely will be using this. If anyone is curious how bad they can be just from sitting for a year or three, here’s mine after 6-7 years of engine enamel covered stock heatshield. 🤢🤮
This was after a bath, and some light scrubbing with a green scotchbrite pad. So Justin’s looks nothing short of amazing after 10-20 years.
Definitely gonna be doing this! What cold galvanizing spray do you use?
