1. Join the Community!
o2 sensor threads stripped, Helicoil will NOT go in.
Posted by pauleyman, Jun 6, 2020
Please Support ExtremePSI
Please Support STM Tuned
  1. pauleyman
    pauleyman DSM Wiseman
    5,859
    1,347
    Joined Nov 19, 2011
    oklahoma city, Oklahoma
    Good grief. I can't tell you how many helicoils I've done and this one just will NOT thread in. I'm using helicoil 4833 o2 sensor thread repair kit. Any tips?
    This is not on a dsm. It's on a 2004 hyundai sante fe 2.4. I have plenty of access to the area but I've tried everything and now I've used up every coil in the kit. I'M DONE for the day. Completely defeated and now I'm 200$ in and still it's not fixed.
    Anybody see this and want to text I'm 405-503-4999.
    Street Build 3K  1
    1997 Eagle Talon TSi AWD
    awd · manual · 2G DSM
    Loading...
  2. EVLGSX
    EVLGSX Proven Member
    656
    249
    Joined Dec 7, 2017
    Wallingford, Connecticut
    cant you just cut the old bung out (carefully) and weld a new bung in?
    Street Build 2K  15
    1997 Mitsubishi Eclipse GSX
    Loading...
  3. pauleyman
    5,859
    1,347
    Joined Nov 19, 2011
    Well piss on it I got it. Those that gave me suggestions thanks. Welding wasn't an option really. Cast manifold. O2 helicoil kit 4833 sucks.
    Street Build 3K  1
    Loading...
  4. miguelmcv
    miguelmcv Supporting Member
    2,666
    187
    Joined May 3, 2009
    Fresno, California
    Can share how you fixed it.
    Would be good to know to fix it, when it comes the time IF need it.
    Street Build 602  1
    awd · automatic · 2G DSM
    3K  0
    1995 Mitsubishi Eclipse GST
    manual · 2G DSM
    Loading...
  5. pauleyman
    5,859
    1,347
    Joined Nov 19, 2011
    I used a helicoil 4833 o2 sensor thread repair kit. I wouldn't recommend it. I've done dozens of helicoils and this one sucked. If you have to do a thread repair if at all possible use a timesert. The usual method of helicoil doesn't work. You have to use their special tool. I went through 6 expensive inserts before I got one to thread correctly. In addition the kit doesn't include a drill bit if you need it. It was a 200$ repair.
    Street Build 3K  1
    Loading...
  6. motomattx
    motomattx Proven Member
    3,024
    1,067
    Joined Dec 9, 2010
    wampum, Pennsylvania
    It was probably cheaper to replace the manifold.
    Drag Race Build 4K  24
    fwd · manual · 2G DSM
    Loading...
  7. pauleyman
    5,859
    1,347
    Joined Nov 19, 2011
    Already looked. It is. Dollars to donuts I would've broken several bolts and the cat for this car is right off the manifold. I'm not touching those. Moot point. Its fixed. Its a cheap car fir my son anyway.
    Street Build 3K  1
    Loading...
Share This Page
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing Raven Fabrication RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
