not boosting, dieing when shifting gears
2GEEZEY
777
Aug 6, 2009
Elgin, Illinois
the other day I was driving home when I heard a little pop noise then it had like no power. I have a exhaust leak out of the o2 housing due to a broken bolt. after driving it hear a tick or a knocking noise coming from the engine. could the turbo have blew? its a 14b.
Sounds like an intercooler pipe coupler came apart to me too. Take a good look and if you still can't find anything you'll have to do a boost leak test. Good luck.:)
What about a knocking noise coming from the engine makes you think you have a blown turbo? And ya you probably popped a coupler off, or if its a cheap one like my old ones you might have popped a hole in it... Take a look at that first then go from there.
okay i need some help, i get this loud " rod knocking" noise only around 2k to 3k, thats when it starts. NOT at idle? could this be a rod? way to loud to be lifters. still no power when i drive it, although, it blows off, but wants to die right away.
This is really weird, because my turbo blew then I swapped a new one on, and I spun a bearing as well LOL
