Please Support RTM Racing
Please Support Rix Racing
2G non-stock alternator identification with picture
NorthEasternGSX
5+ Year Contributor
31
6
Oct 19, 2018
Suffern, New_York
Good evening fellow carnuts. So my alternator started blowing fuses the other day, I took a ride to advanced auto the stock replacement's bolt pattern looks different. The car is a 2g eclipse, with a six bolt swap. The previous owner re-located it with the jay racing kit, and the bolt pattern has a weird offset, he doesn't recall where he got it. Has anyone seen an alternator like this? I've done some searching on the forum but most posts don't have pictures I can use for reference. I'm having a real problem locating a replacement. Any help from the fine people of the DSM community would be greatly appreciated.
Update: My research seems to indicate its a saturn alternator, I'm still doing some homework to make sure, but it could be for a Saturn SL-1 or SL-2
That is the most common swap other than a Galant 90 amp unit.
Anytime!!!!
I just happened to drive a SC2 as a DD (who's fuel pump gave out today on the way to work at 302000 miles 🤔.) I had to get towed home but she is a very good car.
As for the alternator swap, I'm glad you ID'd it and got it shimmed up. Does it line up good and have you been able to start the car for a test or is it in "build mode"?
I'm sorry it took so long for a reply. It's a mod that some do. I run the Galant in the stock location so far. :)
Marty
