tlikethedrink
- 361
- 91
- Sep 11, 2007
ABQ,
New_Mexico
Ok so I just finished changing the timing belt/water pump. I made sure the time was true.
I was about to put it together when I decided to test start it. I test start it, idles fine. Only thing is, there's a funny noise up top. I figured it was the motor mount that i put in 1/2 assed. (It was just to be in case the jack slipped from the engine moving during start/run.) So I pay it no attention.
Now I have the car put together. I start it. Same noise. I've inspected it, it seems to be coming from the top. Not inside the valve cover tho. Outside like the belt was flapping against something. But it made the same noise when there's was no covers for it to flap against.
The car idles fine still. O, and now I've noticed there is a little more slack in the belt up top over the cam gears at some times. Other times it'll be tight. The car has a new tensioner/pulley. Belt is only 10k'ish old. I really doubt it could be valves as the car never was off time. It got a lil hot when the pump went out. But not enough to warp the head. Just enough to get the needle up to almost red. My guess is the tensioner
Ok, so I'm gonna take the car back apart today.
It seems to be running fine other than the noise. I'm still suspecting the tensioner, or the tensioner pully flapping around.
Any wisemen recommend anything to speed up/ease the process? So far all I can think of is setting the car into time while the belt is still on. That way everything's still on on time. O and zip tie the cam gears not to move while I mess with the tensioner/pulley.
Or should i just retime the whole thing?
