revditup
- 0
- Jun 19, 2002
Flora_MS
I just put the rearend w/ 50000 miles on it and it pops and clanks when I let off the gas. I think i even felt it vibrate some. i haven't driven the car at all hardly because I don't want to mess it up worse.
So far:
I checked the lobro joint, took it apart and filled it with new grease, put it back together following my Hanes manual.
I put a new universal joint on right next to the rearend( it didn't have slack in it, just too tight feeling)
I grabbed the axles and wiggled them, they seemed to wiggle inside the rear, but on slightly.
Took my axles to a shop to let them check the CV joints, they said they seem fine and do not need to be replaced.
I took my rearend back out and took the cover off, No slack anywhere that I can see or feel, all the spider gears look fine too.
The side bearings look fine.
I don't know what else too check!
I got in the back seat and let someone drive it so maybe I could tell where it was coming from. It sounds like it's coming from the driver's side, almost like metal hitting metal. Seems like it would be the CV jount but it doesn't have any play that you can feel, and no tears in the boots.
The wheel bearings seem fine also.
PLEASE HELP ME IF YOU CAN!
So far:
